FANUC ARC Mate 100iC Robotic Mig Welding Machine Welds Automotive Components - Courtesy of TranTek
In this robotic mig welding system developed by TranTek Automation Corporation, automotive components are loaded into fixtures on dial tables, which clamp the parts before rotating into a cell where two FANUC Arc Mate 100iC robots use coordinated motion to weld the sub-assemblies together.
The dial tables are fitted with both LH and RH tooling and automatically present the proper fixture to the operator and weld robots for the part being run at that time. This series of weld cells includes one sub assembly dial table weld cell, one sub assembly fixture with bowl fed bracket, one final assembly dial weld cell, and one material handling robot.
A second fully automated weld cell features a FANUC M-10iA robot loading and unloading parts onto a fixture for a FANUC Arc Mate 100iC robot to weld, producing the second sub-assembled part. After the sub assemblies are completed, they are fed into a final welding cell where the parts are manually loaded onto a fixture table. The dial table then rotates the parts in front of two FANUC Arc Mate 100iC robots where final welds are made to produce a finished part.
Follow the link to learn more about FANUC Robotics' full line of Welding Robots.
FANUC M-3iA Picking Pouches of Candy
  • Process specific arm protects and minimizes wear of the torch cable.
  • Highest motion speeds in class for maximum performance and productivity.
  • Best in class reach versus stroke ratio.
  • Compact design simplifies installation and transportation of system.
  • Offers an extremely large work envelope useful for large parts or complex tooling.
  • Extremely fast wrist axes reduces aircut times, thus improving throughput.
