Laser Cutting Robot Machine, Used By Automotive Manufacturers, Cuts Holes Into Automotive Panels - Courtesy of KMT Robotic Solutions
This robotic system, developed by KMT Robotic Solutions, features a FANUC R-2000iB/165F Robot used to laser cut small holes into automotive instrument panels.
Once the operator loads an automotive instrument panel onto a fixture mounted to the robot, he clears the area and presses the cycle start button and the door closes to protect the operator.  The robot then moves the part in front of a fixed laser equipped with a galvanometer.
The galvanometer is capable of performing multiple, high-speed tasks at each robot position.  As the robot positions the instrument panel, multiple, one-millimeter holes are lased into the surface of the part.  When the lasing process is complete the robot returns the fixture to the operator, the door opens and the operator removes the instrument panel from the fixture.  The holes will later be used to create a vacuum on the B side of the instrument panel to remove any air voids when the cover stock is installed and adhered to the sub-straight of the part.
Interested in a Laser Cutting Robot? Follow the link to request a robot quote, or learn more about our Cutting Robots.
FANUC R-2000iB Robot
Laser Cutting Robot
