FANUC M-710iC Car Body Seam Sealing Robot Application
This car body seam sealing operation utilizes four M-710iC/20L robots, two overhead mounted M-710iC/50 robots for hood and deck opening and one overhead mounted M-20iA robot for vision processing of the roof ditch sealing.
FANUC Robotics integrated vision system takes pictures of the vehicle location and sends offsets to the FANUC M-710iC/20L robots that apply sealer to the metal joints of the car interior to prevent water leaks. After the car body is in place, the FANUC M-710iC/50 robots open the hood and trunk of the car body.
While the operation is in progress, the side mounted M-20iA robot with FANUC iRVision moves over the top of the car to locate the roof ditch seam for robotic application of sealer. The M-710iC/20L robots use rail mounts to maximize their reach while applying sealer to the various seams of the car body. After the sealer has been applied, the side mount M-710iC robots close the hood and trunk, and the car body moves onto the next sealant application cell.
Follow the link to learn more about FANUC Robotics' full line of Sealant Application Robots.
M-710iC Robot
