New FANUC P-50iB Robot Paints Automotive Parts in Chain On Edge Machine
FANUC Robotics intelligent paint robots offer manufacturers and suppliers a competitive and affordable advantage in painting and coating applications, including painting in a chain-on-edge environment, as seen in this demonstration.
This demo features FANUC's new P-50iB Robot. The P-50iB Robot is designed to completely paint and coat a variety of products in nearly every industry and manufacturing application. This robot's reach ranges from 1400 to 1800 millimeters; its payload ranges from 10 to 15 kilograms, based on the P-50iB's two different models. Both models of the P-50iB can be equipped with FANUC's patented iRVision software, which can identify parts in multiple orientations.
This demonstration is set up to show the P-50iB Robot's versatility and consistency - both of which are critical in painting in a chain-on-edge environment. The new P-50iB Robot works well for many applications including liquid painting, powder coating, index table painting, and can operate in hazardous environments. In addition, the P-50iB Robot can be mounted in a floor, wall or invert mount.
Put our experience in paint automation to work for you. Follow the link to learn more about our full line of Paint Robots.
FANUC P-50iB Robot
Paint Robot in Chain on Edge Machine
  • High wrist load capability (15kg) allows it to handle rotary atomizers.
  • Compatible with PaintTool Line Tracking, iRVision, Dual Check Safety Speed and Position Check (DCS) and Collision Guard software.
  • Purged and processed arm is FM and ATEX Class 1, Div. 1 approved.
  • Sealed hollow wrist allows manifold-mount applications.
  • Two model variants accommodate 1400-1800mm reach.
  • Floor, invert, wall or angle mounting accommodates a wide range of work areas.
