LVC-Equipped FANUC "Learning Robot" Demonstrates New Advancements in Industrial Robot Cycle Speed
This robotic spot welding demonstration cell features FANUC Robotics' Learning Vibration Control, or LVC equipped R-1000iA/100F "Gakushu," or Learning robot. In the demo, the robot seen on the left is equipped with LVC, while the robot on the right is not. The Gakushu Robot's Learning Vibration Control (LVC) feature improves robot performance by actually learning the characteristics of a specific application path. The Gakushu Robot with LVC provides extremely fast cycle times which optimizes production throughput.
The Gakushu robot equipped with the LVC feature on the left and the robot without LVC apply identical spot welding patterns to opposite sides of a floor pan assembly. As you can see in this side-by-side speed comparison, the Gakushu Robot shows a significant improvement in cycle time compared to the robot without LVC.
With the Gakushu Robot's LVC feature, the software records the path characteristics. The path is run several times, allowing the Gakushu Robot to optimize the path data to improve cycle time.
Running the cycle again, a monitor displays the cycle times of each robot, the improvement in cycle time from the Gakushu robot as compared to a standard robot, and the increase in parts per hour. Once the robots have finished the demonstration, the cycle repeats.
Follow the link to learn more on how LVC can improve your industrial robot cycle speeds.
High Accuracy Positioning Using FANUC LVC
Heavy Payload Robot FANUC M-2000iA
FANUC Robotics' Learning Vibration Control (LVC) allows the robot to learn its vibration characteristics for higher accelerations and speeds After a path is taught, an accelerometer is added to the tool, and the path is run several times in order for LVC to collect learning data. Using the retrieved data, the robot optimizes the motion to have shorter accelerations while keeping vibration to a minimum The accelerometer is only used during the learning process.
LVC, along with integrated iRVision and secondary encoders, work together to provide a highly accurate solution suitable for the aerospace industry. LVC, when used, can decrease cycle times while maintaining accuracy within or beating industry-standard acceptable tolerances.
