FANUC Robotics Learning Vibration Control (LVC) Software, "Gakushu" Robot Demonstrates Higher Robot Speed & Accuracy
LVC is a breakthrough product for operations that require increased accuracy at high speeds allowing the robot to operate with less vibration, even at maximum speed. A FANUC R-2000iB/165F robot simulates drilling an aerospace panel. Without the Learning Vibration Control software, the cycle time is 11.5 seconds. With the LVC software, the cycle time is 14% faster finishing in 9.9 seconds.
FANUC Robotics high accuracy solution provides absolute accuracy in a given area allowing the robot to be accurately positioned. Secondary encoders allow the robot to accurately locate the tool and drill holes.
iRVision snaps an image to yield edge positions after the part has been altered. The edge positions create a path to guide the robot around the object. The first path simulates cutting with a waterjet or plasma cutter. The second path applies a tool offset to the path for material removal.
Learn more about FANUC Robotics' full line of Robot Software Features.
R-2000iB Robot
High Accuracy Positioning Using LVC and an R-2000iB/165F Robot
FANUC Robotics' Learning Vibration Control (LVC) allows the robot to learn its vibration characteristics for higher accelerations and speeds After a path is taught, an accelerometer is added to the tool, and the path is run several times in order for LVC to collect learning data. Using the retrieved data, the robot optimizes the motion to have shorter accelerations while keeping vibration to a minimum The accelerometer is only used during the learning process.
LVC, along with integrated iRVision and secondary encoders, work together to provide a highly accurate solution suitable for the aerospace industry. LVC, when used, can decrease cycle times while maintaining accuracy within or beating industry-standard acceptable tolerances.
