FANUC M-1iA Robotic Assembly of a Cicuit Board
In this robotic application case study of robotic small part assembly, two FANUC M-1iA/0.5A 6-axis robots assemble and inspect a computer board.
The second M-1iA robot picks up and installs two fuses to the board. iRVision error proofing is used to inspect various areas of the computer board. iRVision error proofing helps to ensure part assembly and provides 100% inspection on the fly. The FANUC M-1iA is designed for small part handling, high speed picking and assembly applications.
Learn more about FANUC Robotics' full line of Assembly Robots.
M-1iA Robot
  • iRVision is built-in.
  • 4-axis and 6-axis variants.
  • A 3 axis wrist makes the M-1iA extremely flexible and versatile compared to traditional SCARA robots.
