FANUC M-1iA Robot Assembles & Disassembles LED Lens
Two FANUC M-iA/0.5S four-axis robots equipped with iRVision/2D assemble and disassemble small LED Lens into PCB bases. The robot uses built-in iRVision/2D to locate the LED lens and trays. The robot offers high speed assembly precision with rates over 130 cycles per minute.
The FANUC M-1iA is designed for small part handling, high speed picking and assembly applications.
Learn more about FANUC Robotics' full line of Assembly Robots.
M-1iA Robot
  • iRVision is built-in.
  • 4-axis and 6-axis variants.
  • A 3 axis wrist makes the M-1iA extremely flexible and versatile compared to traditional SCARA robots.
