FANUC M-3iA Robot Loads Conveyor Buckets with Candy Pouches - Courtesy of Remtec
In this application engineered by Remtec Corporation, a FANUC 4-axis M-3iA Robot picks randomized pouches of candy and placing them into buckets on a continuous cartoner infeed conveyor. The design rate for the application is 90 pouches/minute.
The system is designed to operate in three modes:
• Picks semi-random pouches straight from the pouching operation.
• Picks pouches from a hopper-fed buffer conveyor with a pouch flattener.
• Combined mode -- either direct or hopper-fed.
The application uses Fanuc Robotics' iRVision with visual line tracking to locate the pouches to be picked. In addition, the cartoner conveyor is being tracked by a separate encoder and fed to the robot controller, making this a dual-tracking application. iRvision is also used to reject crushed and overlapping pouches, which are simply recirculated to the hopper and later flattened and reintroduced via a buffer conveyor. The black belt on the pick conveyor allows iRVision to be configured so that white, silver metallic, and even clear pouches can be picked with one Vision Process.
Follow the link to learn more about FANUC Robotics' full line of Picking & Packaging Robots.
M-3iA Robot
FANUC M-3iA Picking Pouches of Candy
  • Available in a 4-axis or 6-axis designs
  • iRVision and FANUC force control are supported on both models
  • Unique parallel-link design maximizes speed and acceleration
  • Higher speed and acceleration reduces number of robots needed for an application, condensing overall footprint of a manufacturing system
  • Six-axis design (three-axis wrist) enables part feeding from the sides of a work zone, increasing the useable workspace
  • Four-axis design (single-axis wrist) moves parts at extremely high speeds
  • Food option with food-grade grease features a special coating to handle acid and alkaline disinfectants, and low-pressure rinsing
  • Ability to work with primary (unpackaged) or secondary (packaged) food products
