FANUC M-710iC Robot Transfers Parts By Robotic Bin Picking
A FANUC M-710iC robot equipped with iRVision locates and picks randomly piled parts from a storage container. iRVision is first used to verify the correct grip position before the robot transfers the part. The robot then transfers the part to a second container. iRVision with high speed continuous motion is then used to detect defective parts.
Learn more about FANUC Robotics' full line of Part Transfer Robots.
M-710iC Robot
