M-710iT robot loading multiple machine tools
A FANUC M-710iT robot loading multiple machine tools. The M-710iT top loader robots have a 70 kg payload. A dual part gripper is used for the machine tool unload to speed up the cycle time required to remove the parts. The use of the M-710iT top load or articulated gantry offers the advantage of tipping the part to remove the coolant and also loading the part in either a horizontal or vertical format. Since the top loaders are mounted to an overhead rail, the floor space around the machine tool is free for maintenance access
  Made For Machine Tools
  • Increased productivity. Robots increase machine production by up to 20% over traditional methods.
  • Perform secondary operations. For longer machining times robot can perform deburring or guaging of finished parts.
  • Improved Ergonomics. Robot can eliminate workman's compensation and operator safety issues with moving heavy parts.
  • Increased Quality. Built-in vision can 100% inspect.
  • Robot repeatability assures placement in chuck.
  • Eliminate Fixtures. Vision can be used to find parts on belt conveyor(2D) or on pallet(3D).
M-710 iT robot
  • Services multiple vertical and/or horizontal machines.
  • Adapts easily to existing plant layouts.
  • Performs value-added processing operations such as gauging, deburring, deflashing, and labeling, in addition to basic material handling tasks.
  • 70 kg payload capacity.
  • Balances asynchronous processes by maintaining in-process part buffers.
  • Improves machine productivity by as much as 30 percent.
