FANUC Palletizing Robots Improve Cycle Speed with Learning Vibration Control (LVC) Software
This demonstration highlights FANUC Robotics' integrated iRVision and the new Learning or "Gakushu" Robot. In this automated palletizing and depalletizing demo, the FANUC R-1000iA/80F robots, use iRVision bar code reading to sort two different types of boxes from a conveyor. The robot in the background picks individual boxes of two different colors and places them onto a conveyor. As the boxes move down the conveyor, the robot in the foreground reads the box's bar code using a camera equipped with iRVision, and tightly stacks the boxes in a checkered pattern.
The boxes are then depalletized back to the conveyor and the cycle repeats. Bar code reading is ideal for customers who need to identify and separate box styles during the palletizing cycle.
The second portion of this demonstration highlights FANUC's "Gakushu" robot with Learning Vibration Control -- or LVC. LVC improves robot performance by actually learning the characteristics of a specific application path. The FANUC "Gakushu" Robot in the foreground, which is an R-1000iA/80F robot equipped with LVC, races against an R-1000iA/80F robot without LVC. With a 'Gakushu' robot, software records the path characteristics using an accelerometer mounted to the end of arm tooling. The path is run several times, allowing the "Gakushu" robot to optimize the path data to significantly improve cycle time.
In this example, the "Gakushu" robot shows a 12 percent improvement in cycle time compared to the robot without LVC. The cycle time improvement from 'Gakushu' robots can significantly increase the productivity of robotic palletizing systems without the added time and expense associated with typical expert programming strategies.
Follow the link to learn more about FANUC Learning Vibration Control (LVC).
R-1000iA Robot
  • A large operating space (including its rear and downward side) due to a serial link configuration.
  • High-speed approach from home to working position and fast positioning in short pitch motion can minimize the required time of process.
  • The R-30iA robot controller enables intelligent functions including integrated vision and networking options.
  • The R-1000iA is made as slim as possible in width and provides accessibility to adjacent robots, fixtures, and workpieces.
High Accuracy Positioning Using LVC and an R-1000iA Robot
FANUC Robotics' Learning Vibration Control (LVC) allows the robot to learn its vibration characteristics for higher accelerations and speeds. After a path is taught, an accelerometer is added to the tool, and the path is run several times in order for LVC to collect learning data. Using the retrieved data, the robot optimizes the motion to have shorter accelerations while keeping vibration to a minimum. The accelerometer is only used during the learning process.
LVC, along with integrated iRVision and secondary encoders, work together to provide a highly accurate solution suitable for palletizing. LVC, when used, can decrease cycle times while maintaining accuracy within or beating industry-standard acceptable tolerances.
