Picking and palletizing cases
A FANUC M-20iA robot with a vacuum gripper picking and palletizing cases at a rate of up to 40 cases per minute. The robot easily handles multiple pallet patterns and case sizes. A teach pendant offers customized and friendly controls for the end user. In feed designs are customized to fit user needs. This application can handle single or dual pallet configurations.
  M-20 iA Robot
  • 20 kg payload at wrist.
  • High joint speeds maximize throughput.
  • Built-in Solution Arm, 50 mm hollow wrist and upper arm.
  • 6 degrees of freedom.
  • ± 0.10 mm repeatability
