Placing Foam Pads on Insulin Pumps
A FANUC LR Mate 200iC robot is shown vacuum picking foam pads from a roll and placing them on insulin pumps using iRVision. The camera is mounted directly above the feed slide where a snapshot is taken of the two pads over the red backlight. The foam pads are compared to a fixed position where the robot will move to secure the foam pads. The vision correction offsets the positions used when the foam pads are applied to the pumps.
LR Mate 200 iC Robot
  • The six-axis, LR Mate 200 iC robot rates ‘best in class' for its wrist load capacity, repeatability, work envelope, and speed.
