This Pick and Place Robot's Speed and Accuracy Simply Cannot Be Beat
The new FANUC M-2iA Robot is the third in a series of FANUC's high-speed parallel-link delta robots that also include the M-1iA and M-3iA robots. Two new models of the FANUC M-2iA Robot are available; The FANUC M-2iA/3S, and the FANUC M-2iA/3SL long-arm model seen in this demonstration. Both models offer a 3 kg payload, four axes of motion and a single-axis rotation at the wrist.
In this demonstration, the M-2iA picks and places mint containers from an inbound conveyor to an outbound conveyor at an amazing 182 parts/minute -- That's approximately 3 parts every second. In addition to simply picking and placing the containers at extremely high speeds, the robot also orients the parts in the same, consistent position. The robot does this through a combination of its single-axis wrist - which offers speeds up to 3500 degrees per second - and through FANUC's iRVision Line Tracking system. This monitor displays what the robot's camera is seeing.
The FANUC M-2iA Robot is ideal for applications requiring high-speed and accurate handling. It's handling capabilities include a wide range of products including electronics, medical devices, pharmaceuticals, cosmetics, office supplies, and consumer products, among others. A completely enclosed structure also makes it safe for food environments.
Interested in a FANUC Pick & Place Delta Robot? Talk to us today!
Follow the link to speak with a FANUC representative today, or learn more about our full line of Pick and Place Robots.
FANUC M-2iA Robot
  • Portable and compact size allows operation in small spaces.
  • Four-axis design (single-axis wrist) accurately moves parts at extremely high-speeds.
  • A hollow wrist allows tooling cables to be routed internally, minimizing wear and tear.
  • Food option features a special coating to handle acid and alkaline disinfectants.
  • Ability to work with primary (unpackaged) or secondary (packaged) food products.
  • Optional IP69 rating for the entire robot means the robot is waterproof and can withstand harsh environments, including dust and high-pressure cleaning.
  • Supports FANUC’s latest intelligent features including iRVision and force sensing.
